I am using the 'category:set sort order' to sort a database on the fly in my skin but am experiencing some slightly strange behaviour.
It seems that after I sort a database the sorted XML file does not get saved to disk. I know this because I am making some changes to the database in a VB.NET plugin (directly on the XML file) and when I refresh the database in xlobby the sort order has been screwed up.
2 questions really..
1) Has anybody used 'set sort order' much and had any problems with it?
2) Should xlobby save the xml file after the 'set sort order' command? (One for Stephen I guess)
Thanks for any help you can give.
