XML Database on DVD
XML Database on DVD
Postby Myth on Sat Oct 01, 2005 8:18 am
Hi ,
Is it possible to link to a database (eg TVSeries_On_DVD.xml ) residing on a DVD.
What I'm thinking is that I put in a DVD with a TV series on it, then select the View TV Series ON DVD page and it looks up the XML database on the DVD.
Can I do it? If so How?
Myth
Myth
Postby Myth on Mon Oct 03, 2005 9:33 am
Bump :wink:
yes.... No..... Maybe??
tah
Myth
Myth
Postby dgemily on Mon Oct 03, 2005 11:34 am
the only way that I know, is by using the plugin Xant. but you have to build your datbase with Ant Movie Catalogue.
dgemily
Postby badubo on Mon Oct 03, 2005 11:44 am
you can use XAnt that creates, at runtime, a database related to your DVD either
- with data comming from 1 (or several) xlobby databases
- with names of files and coverart found in the dvd (maybe less usefull for you)
This is done when inserting the DVD
badubo
Postby Myth on Thu Oct 06, 2005 11:12 am
Was hoping for an XLobby only solution. Nevermind, I'll look into this XAnt db
Thanks for your help
Myth
Myth
