new event: Refresh database with delete not found
Got an idea, post it here
Postby lar282 on Fri Feb 08, 2008 9:29 am
MOVIE database:
I would like to see a new event that refreshes the database and automatically deletes the entries not found. Since the new XL has an xml file for all entries, it will add it again with all information when the files are there again.
why?
If I delete a file manually(a movie) and then refresh the database I have to go into F2 and delete the entry manually. Would be much smoother if XL did delete the entry if the movie is not there! And no I do not want it to set the movie for Offline.
