I notice that when I record TV shows using the xltv plugin with K!TV, the recorded show files are huge. 1GB per 1 minute of show. Is there any way I can reduce the file size? Or is this just the way it has to be.
I haven't openly used K!TV, but it sounds as though it is a setup issue with that program. Sounds like you are using a lossless codec. What are the file types that your recording? See if you can go into the setup of K!TV and change the compression ratio or codec.
