sharp_1 wrote:You would use the 1/8" output jack on the USB-UIRT:
to your projector with an IR Repeater:
Works like a charm!!!
cmhardwick wrote:I'm assuming currently you control the projector with an IR remote? with the hardware sharp_1 mentioned, xLobby can learn the commands from your existing remote and you can then create an event where xLobby will play back those commnads, thus emmulating your remote.
homepc wrote: The XL button would have to send a signal to the projector to switch to a differant input for video, and it would have to send a signal to the reciever to switch to a differant input for audio. Is this possible?
sharp_1 wrote:homepc wrote: The XL button would have to send a signal to the projector to switch to a differant input for video, and it would have to send a signal to the reciever to switch to a differant input for audio. Is this possible?
This is exactly what I do right now with this configuration...works like a charm!!! That's what makes xLobby so great!!!
but wait, after I switch to a differant input on my projector using XL, I can no longer see the XL screen obviuously. How do I get XL to switch the projector back to the input for the computer?
m_ski wrote:but wait, after I switch to a differant input on my projector using XL, I can no longer see the XL screen obviuously. How do I get XL to switch the projector back to the input for the computer?
When you switch to projector also have xlobby go to a special screen with 1 giant button filling the entire screen. The event on this button could be setup so that 1 click of the mouse will then fire off the IR commands to return the projector to xlobby input.
If you can think of it then xlobby can do it one way or another...
you have an extra analog-digital and digital-analog conversion going on, it is bound to lose a bit of quality
