Groover wrote:Can you switch between the screen here Gamejester - meaning - can you display Xlobby through the projector if you want? How do you find a touchpanel in comparison to a remote. Can you access it from your seated position, or do you have to lean forward (a real pain to change the volume all the time). What are touchscreen disadvantages compared to a remote?
Thanks Groover
You can't toggle displays especially as they probably will be running at different resolutions, plus, you can't have 2 Xlobbys running at the same time - something to do with running 2 full screen directx apps.
I have a htpc case with a 7" touchscreen at the front linked up to a 32" LCD tv. I have a NVidia 6800 passive card in the pc with vga to the touchscreen and DVI to the LCD with windows setup to have the LCD as primary display. I have 2 Xlobbys setup, 1 designed at 1024x768 for the touchscreen using Baddabings Bong skin (great for touchscreen) and the other runs at 1366x768 using a modified HeavyMetal skin. As you can select in Xlobbys setup which connected monitor to use, this means you can point 1 at the touchscreen. Using the touchscreen I don't have to have the tv on to have music, radio, weather - although I can fire up milkdrop to run on the tv if needed (as it will run on the primary display).
I have a .Net app that switches between the 2 Xlobbys killing the process of the currently running one (and winamp and zoomplayer) and firing up the other (all wired up to the green button on the MCE remote via girder). All volume through av-receiver again controled by MCE remote.
Plus as these are all running on 1 pc (that runs both xlobbys as servers) I can also access the currently running one on my ppc phone - what an amazing bit of software
Works fine for me - mostly
