That way it will be easy to filter out not watched movies and tvseries
hvs69 wrote:I think it should be doable by setting a "watched" field in your movie database and controlling it with "variable set" event (for example when you hit the Play button to play the movie)
lar282 wrote:hvs69 wrote:I think it should be doable by setting a "watched" field in your movie database and controlling it with "variable set" event (for example when you hit the Play button to play the movie)
This works cause I have it like that.
I would like that xlobby created a default field "watched" when importing movies,with default value not watched.
