Sorry about the Subject title, but I don't know how to condense my problem into six(ish) words!!
I have a laptop with Xlobby running as a fat client. This is connected via a WPA encrypted WiFi connection to a server which contains all my music (about 20Gb in mp3).
Xlobby runs fine with this setup.
I also have a iPaq PDA with Bluetooth which I can connect to my laptop (even with the Wifi connected).
What I cannot do is connect my PDA with XLobby (to use as a remote/thin client) via Bluetooth whilst Xlobby is connected to my WiFi server (the one with the music!).
I have tried everything - connecting the PDA to laptop before running Xlobby doesn't work as Xlobby changes the server address to the WiFi address.
I have tried to change the Xlobby.xml file to read only in an attempt to stop Xlobby from changing it - but it does not work.
If I turn off WiFi and boot up Xlobby I can connect to the PDA via bluetooth.
The reason I don't use the laptop as a controller is that I plug it into my 32" LCD HDTV via RGB and into my DD amp and I would like to control it via PDA.
Ultimately I would also like to make the move to storing my Divx / DVD's to view via Xlobby as well!
Any Help???
