DO NOT ATTEMPT THIS IS YOU ARE NOT COMPETANT WITH WINDOWS!!!!
THIS IS DONE AT YOUR OWN RISK! - SO DONT BLAME ME IF YOU HAVE TO FORMAT
This is a guide for WINDOWS XP
Do i need any specific software?
Optionally you can use a program called ShellOn v3 to change the Windows shell, this i would recommend
http://www.dx13.co.uk//programs/sov3/ShellOnv3_rc2.zip
1. Auto login to a specific user
To make Windows automatically login to your account use the following instructions:
START > CONTROL PANEL > USER ACCOUNTS > 'CHANGE THE WAY USERS LOG ON AND OFF' > UNCHECK BOTH OPTIONS > APPLY OPTIONS
START > RUN > "CONTROL USERPASSWORDS2"
- Select the user you wish to use
- Uncheck 'Users must enter a username and password to use this computer'
- Apply
- Enter passwords
2. Change the Windows shell
I suggest that you create a batch file to set as the shell, rather than use Xlobby.exe, this will mean that you can start other programs up easily (eg. Reg Kill...).
Firstly make a shortcut to XLobby.
- Right click on XLobby.exe
- Select 'Create Shortcut'
- Name it 'startXLOBBY'
Open Notepad
START > ALL PROGRAMS > ACCESSORIES > NOTEPAD
Type in the location of the XLobby shortcut, eg:
start C:\startXLOBBY.lnk
(keep the 'start')
FILE > SAVE AS
- Change 'Save as type' to 'All files'
- Enter in your file name, follwed by .bat
- Eg. Startup.bat
- Unzip the ShellOn v3 program downloaded earlier
- Double click and run 'Config'
- Press 'OK' to all the boxes that appear
- The main window will now be open, right click in the white area and select 'Add'
- Fill in the details for your batch file
- Press 'OK'
- Right click on the shell you added
- Select 'Set as Shell'
- Click the 'Settings' tab
- Press 'Set ShellOn as Shell'
- Check under 'Information' that the shell has changed from Explorer.exe, to your batch file
- Press 'OK'
- Reboot!
How do i get back to normal Windows?
- Press CTRL + ALT + DEL
- FILE > NEW TASK
- Type in: explorer
- Press 'OK'
This is V1.1, so if there are any changes then please suggest them.
Like i say this is done at your own risk!
It should be straight forward enough though.
