Help me chat?
Help me chat?
Postby Colby on Mon Oct 04, 2004 2:41 pm
I cant get my chat to work on XL. Its not an xlobby thing its a java thing. I know because I cant play java games either. I went to sun/java web and downloaded the latestest, not that it did anything. I am running winXP SP2.
I would like to be able to chat to with other xlobbists.
Postby jowaldo on Mon Oct 04, 2004 3:35 pm
you could always just use mirc
Postby rhinoman on Mon Oct 04, 2004 4:02 pm
Mine hasn't worked since sp2 either, I guessed it was broken since the new server.
rhinoman
Postby edgley on Mon Oct 04, 2004 9:06 pm
If its a SP2 issue, it will be the firewall.
If you are behind a router you might need to forward the port as well.
edgley
Postby rhinoman on Mon Oct 04, 2004 10:55 pm
The firewall is off on my machine because I'm behind a router. Its not the router because it used to work fine.....
rhinoman
Postby Colby on Fri Oct 08, 2004 7:03 pm
I had chat working b4 too behind a router. I removed and installed the latest java app from sunjava website. This didnt make a difference. I am at my whits end. I want to be able to chat so I can answer questions and help more in real time.
Postby stevenhanna6 on Fri Oct 08, 2004 11:44 pm
try it out now, I couldnt get it working either so I changed a setting for the irc client...seems to be working now.
Postby Colby on Sat Oct 09, 2004 12:25 am
still no go for me. :(
Postby rhinoman on Sat Oct 09, 2004 7:27 am
Works for me now.
rhinoman
The Java Runtime Environment cannot be loaded
Postby Colby on Mon Oct 11, 2004 6:20 pm
Ok Im chatting again. The error was:
The Java Runtime Environment cannot be loaded from <C:\PROGRA~1\Java\J2RE14~1.2_0\bin\hotspot\jvm.dll>
I dont know why this worked but by deleting the entire Java directory in
c:\Documents And Settings\MyUserName\Application Data\Sun
It works again.
So I am up and chatting again. And feel free to ask me questions or meet me on chat for help. I know a thing'r two about a thing'r two. :)
