by Colby on Sun Mar 28, 2004 4:23 pm
I am not very familiar with PS elements, however I am with PS. In PS you can choose the paint color set it to back, then go to the filters menu and select stylize, glowing edges. Or, another way would be to create outerglow in the blending options, which you can get to by right clicking on the layer. These are only a couple of options in PS, I dont know if they are available in ps elements. Good luck.
