Part of the problem is advertising and another part is installation/documentation. I think if more people knew about this software and the forum it would help. This software is geared more to the DYI geek type automation junkie. (no offense meant to anyone here). For the last couple of years I have been toying with going to Homeautomation for a new house I am building. I started with a simple package from HAL and looked at Homeseer and at a nicer front end for these packages from cinemaronline.com. The cost really add up. It was just by accident I ran across something in the Homeseer forum about Xlobby. I used google to search for Xlobby and downloaded it last week. It seems really good once you set it up. The hard part is to get it setup correctly. For instance it was not really clear that you need to download and install Xlobbypre2 so I just download Xlobby2 and it promptly crashed. At this point most people would just walk away. I looked around the forum and found I needed Xlobbypre2 and xlobby2 installed. To be honest these should be in ONE package. I then tried to add BB's great skin. It came up with a black screen. I dug around the documentation a bit more and discovered the files did not get placed in the correct location. Finally got that fixed. Showed the wife and she likes the front end. Having a good WAF is good. Next I tried to install TV as I have a TV tuner card. Discoverd the hard way that my ATI-Radeon 5700 does not work with the sytem. Now Xlobby crashed with a error report request to MS. Solution add another video card that is supported. Still have to get that or do a fresh install of xlobby. Also there does not to be any central point for downloading everything from skins to tv support. Things that would help push this great software.
1. Better installation method.
2. Slight better documentation.
3. All parts, including plugins, skins, etc, in one place instead of scatter in the forum messages.
4. Having a pay for support method. That way people that are not geeks can implement Xlobby.
5. Adding of new features like direct RS-232 control
6. More user promotion in other forums.
Just my 2c worth
Tom
