bsplayer commands and show info in xlobby
Postby marque on Fri Feb 11, 2005 12:11 pm
I read that for bsplayer it is possible to send info about status volume and position, is it possible to make an plugin to show that info in XL or use it just like winamp?
You can find the bsplayer sdk here
My eventgroup to control bs player with send message commands can be downloaded here (right click, save as....)
marque
Postby stevenhanna6 on Fri Feb 11, 2005 7:33 pm
One of the major things I need to know when I use foobar and winamp, is the current playlist position...I cant seem to find that there. I also need to get the track position in milliseconds if possible.
Postby marque on Fri Feb 11, 2005 8:08 pm
Do you need something like this:
// mov_pos = SendMessage(bsp_hand,WM_BSP_CMD,BSP_GetMovPos,0);
// available in BSPlayer version 0.84.484+
// Return current movie position in msec
#define BSP_GetMovPos  0x10101
It also seems that girder pugin called dvd spy can retreve alot of info from mediaplayers and show it in some osd's so maby it is possible to show it in x lobby to.
My knowledge of programming is very smal so I can not do that much myself but i'm sure this fauture wil make xlobby look very slick 8)
marque
