Currently eventbuttons can have an eventID that points to the predefined events.
It would be nice to assign a command directly to a button. Especially if you want to "goto xxx" you wouldn't have to create an event, then assign the goto command to that event and finally select the event from the button.
It sure would speed up the skinning proces.
I could easily live with a limit of one command per button if nescessary.
