Naming Playlists
Naming Playlists
Postby cwellsaz on Thu Dec 02, 2004 5:07 am
When I same a playlist it names playlist 1, 2,.... and so on. Is there a way to bring up a overlay when the save playlist button is pressed to let you name your lists. If not it would be sweet.
cwellsaz
Postby lar282 on Sat Dec 11, 2004 7:41 pm
I got a worse problem. I can save ONE playlist but not more? Have to restart xlobby to save another one?
bug/by design?
Postby Marbles_00 on Fri Mar 03, 2006 4:00 pm
Bump!
It's been a while since this one was posted, but is it possible yet? Or is there a default naming scheme within Winamp that can be altered in its configuration/setup maybe? I'll have to check on that, but in the meantime, I'd like to be able to save the playlist depending on the zone the playlist was created in.
Example:
If a zone is setup in the masterbath and the wife wants to create a playlist ahead of time for that zone, so when she goes to have a bath in peace and wants to listen to some music, she only has to select the playlist labeled "Bathroom".
Or better yet, I set up a zone named 'Party' (using a Soundblaster card with KX drivers, there is a setting to drive all the outputs from one instance of Winamp) and wish to create a playlist that I can load up quickly for some party later that day. Then I can quickly load that playlist from the list and set the zone.
Postby rembetis on Wed Jul 19, 2006 5:56 pm
Bumpity bump. Wondering if any progress has been made on the ability to name a playlist from within Xlobby.
rembetis
Postby Colby on Wed Jul 19, 2006 9:19 pm
My Bluezskin has playlist renaming in it. It works fine.
Postby rembetis on Wed Jul 19, 2006 11:05 pm
Thanks for the heads up Colby. I'll take a look and see how you managed it.
rembetis
Postby dalanik on Thu Jul 20, 2006 8:06 am
Yes, new versions of XLobby do have rename for playlists. When you save playlists, they get names like Playlist1, 2 etc. then you can rename 'em...
D.
Postby jowaldo on Fri Jul 21, 2006 10:48 pm
dalanik wrote:Yes, new versions of XLobby do have rename for playlists. When you save playlists, they get names like Playlist1, 2 etc. then you can rename 'em...
D.
yep, if you make an event to save a new playlist then have something like an overlay pop up right away, you can rename it and never even know that it was temporarily called playlist 1, 2 etc...
Postby dalanik on Sat Jul 22, 2006 6:22 am
Ah, but you would have to be CERTAIN of the saved playlist name! If you already had playlist1 playlist2 , xlobby would save it as playlist3... so it'd take either a small script to check existing playlists and then rename the one with the highest number or something similar....
D.
Postby S Pittaway on Sat Jul 22, 2006 1:13 pm
i dont think you would have to check anything....
i would assume that becuase it had just saved that playlist it would be the "active" one and that would get renamed???
I havent got round to wiring in rename yet, so i cant say for certain :)
Postby jumpman23 on Thu Nov 30, 2006 7:48 pm
I don't understand this:
I can rename playlist only if there isn't playing playlist.
And I rename only the last m3uplaylist if any playlist playing.
Bug?
jumpman23
