I just received my usb-uirt and was ready to follow the instructions of the le plugin xremote instructions but I can't get past the first step. When I put the xremote.dll into the plugin file and then start up xlobby it runs through all the files like it is loading and then when everything loads up xlobby just disappears and does not come online. What am i doing wrong? Was there something else I should have done first? I am pretty sureI have the latest version of xlobby. I am using Heavy Metal skin but had the same issue with the default.
ok i will check the version and also check for the plugin when I get home tonight. Can anyone explain why/if these issues would keep xlobby from starting up as described before?
Thanks!
Thanks guys! Somehow I didn't have the correct version. Strange as I have only been using it for like 2 months. I basically only had to replace the couple of parts into my older version and I didn't have to start over.
