Hi all,
Is there any documentation on searching / filtering databases? I'm using Naylia's skin which doesn't have it built in, and not getting very far after about 6 hours work on this.
I've got a 'Filters' button on my movies list screen, which shows an overlay window with more options. One of these is A-Z search which shows a keyboard overlay. The keyboard buttons just do show>a, show>b etc. and this works fine.
The other buttons are for filtering genre etc, and these all do absolutely nothing. I've tried doing set filters, custom searches etc in the events and it just never has an effect. I'm now completely out of ideas.
I've copied most of this stuff from the default skin, and got an install of Xlobby now on another machine using the default skin so I can compare settings. It all looks the same, just doesn't work in the XLobbyMC skin.
