Media Player Classic
Postby Bill Lott on Sat Jun 19, 2010 4:53 pm
I'm using MPC to view my HD movies within xLobby. Is it possible to create events and assign buttons that could control Media Player Classic?
Bill Lott
Re: Media Player Classic
Postby Bill Lott on Wed Jun 23, 2010 1:25 am
Got it figured out using the os>send message commands. Works like a champ...
Found the answers here viewtopic.php?f=6&t=1866&p=11632&hilit=mpc+commands#p11632
Bill Lott
Postby vaporhat on Wed Jun 23, 2010 12:14 pm
Good to hear you figured it out... and thanks for posting back your findings.
Points for digging up a 6 year old post for your answer :)
Postby billberet on Wed Jun 23, 2010 4:42 pm
wow, you ain't kidding when you said 6 years
koodoos to you for finding a needle in a haystack.
Postby cx72go on Tue May 03, 2011 7:02 pm
I have tried and read several years worth of posts here on using os/send message for controlling mpc HT, right now when starting a movie from my hard drive using Xlobby Heavy Metal TS skin I use a Microsoft remote control(RC6) for pausing and playing and closing.
What I have tried is
Class Name: MediaPlayerClassicW
Window Name: Media Player Classic
Message: command or 273
wParam:888 or 156
IParam: 0 or 1 or 5
I am using Windows 7 64 bit when activating the buttons I use for executing the pause or play the task bar appears above the current movie playing but nothing else happens. I have also tried to learn the IR codes from the Microsoft remote but same thing happens as I described above. I have I missed something in the send message setup?
Any help is greatly appreciated..........
JD
cx72go
