by trevis on Sat Sep 06, 2003 8:17 pm
Hey matt,
Check out avsforum.com for more info on connecting an HTPC to an HDTV. I myself run my HTPC on a DLP front projector, but i also have a "small" 46" HDTV that i mostly use for games. Also, it has DVI input. A few months back I decided to check out the HTPC on that TV and ended up having to tweak things quite a bit with Powerstrip. It seems that TV's even HD ones have really horible overscan and understan - the image is either cut of on one more edges or one or more edges dont meet the edge of the screen.
There are lots of threads on AVS about using powerstrip for correcting these issues, and as long as you've got the patience it should be posible.
The other issue that i ran into is that the HDTV was never really intended to be used as a computer monitor so *mine* dosen't support any of the standard VGA modes which means that i couldnt see the boot sequence and had a tough time seeing powerstrip inorder to tweak things. I ended up using a wi-fi notebook PC and a remote desktop application called WinVNC.
So, yes HDTV+HTPC is posible, and clearly if you're going to use it for movies the size will be a very very very nice thing, the bigger the better but HDTV's are not PC monitors making desktop stuff kind if a pain. Some of the nicer plasma models that do support higher resolutions and DVI seem to be much better in this regard, but then again 4k+ for a TV isnt really posible for everyone.
If you can, i'd try to see if you can get your HTPC and this TV into the same space for a little while so you can test it out so you can know what you're gettting into.
Good luch.
