As I have started integrating your xltv plugin into my skin, I have encountered a few issues and thought of a few features that I wanted to bring it to your attention. BTW, this plugin works wonderfully in its current state and thanks for providing all the support.
- Currently for MT, when your plugin writes the EPG data file it grabs the channel information from MT database. I would like an option to have that information grabbed from the original xmltv database. This is because the MT database does not have the channel number whereas xmltv file has that number. This will allow the channels to be sorted in the order of "channel number" rather than "channel name" in the EPG.
I would also like to see an option of turning off channel logos in the EPG grid. Because of the size of the grid the channel logo on my RPTV cannot be seen clearly and I would like to turn that off. I like the channel logos to be shown separately outside the EPG grid.
When I go into the Skin Editor or Setup (F2) screen, I believe your plugin mutes the wav output of the pc and minimizes the MT window. I think your plugin sends a toggle command to the sound device. Very many times, this leads to the system muting off when the MT window is active and turns back on when I go into the Skin Editor or Setup mode. I am not sure why it happens. Is it possible to send discrete mute/unmute commands rather than toggle between these two states ?
For Record function, is it possible to have options like ("Record Daily", "Record Weekly", "Record Once" etc.). I know that this would mean that your plugin has to Scan the EPG on a regular basis and update the scheduled tasks. This feature would make this system so close to a set-top PVR box
This is a minor visual enhancement. Can you associate a skinnable graphic (png) to Channel>Now>Pc field ? This would allow us to see a nice progress bar for each show.
Once again, thanks for this great plugin. I am hoping that you can implement these changes in the future release.
