Overlay problem
Overlay problem
Postby glamdring on Mon Dec 06, 2004 4:24 pm
I am running into a strange problem, I am using jwaldo's skin and have setup the auto-play features. When I put a disk in the overlay does not show up properly, it is there, but I can only see it by moving my mouse around the screen, which causes the buttons and test of the overlay to show up. I tried using a button to open the same event and the overlay came up properly. Does anyone have any ideas why this might not be working?
glamdring
Postby edgley on Mon Dec 06, 2004 5:26 pm
Have you set up in F2>Misc the CD auto play options?
This is the only thing I can think of.
edgley
Postby glamdring on Mon Dec 06, 2004 5:45 pm
Yes they are set, and the autoplay is working, but the overlay does not display properly.
glamdring
Postby dgemily on Mon Dec 06, 2004 6:57 pm
it's the same for me and others french users, I think that is a bug : http://www.xlobby.com/forum/viewtopic.php?t=2480
later
dgemily
Postby Noux on Sat Dec 18, 2004 9:04 am
Hi, :D
Does anybody know if the problem is solved, or if there's a way to bypass it ?
I'm french, and also have this "bug"...
Noux
Postby JSL on Thu Dec 30, 2004 12:06 pm
I have experienced the same problem.
The way I circumvented the issue was to add the command "button select" in the “dvd popup”-event referring to one of the buttons on the overlay.
Exactly what I have done is:
1) In the popup overlay I ID'ed my Play button to "DVDPlay"
2) In setup I made xlobby's AutoPlay call the autoplay:dvd popup-event (xlobby does this by default)
3) In the Event Manager under the "dvd popup"-event I added the "button select" command referring to the Button ID: "DVDPlay" (so the "dvd popup"-event now execute to commands i) "show global overlay" ii) "button select" (ID:DVDpopup).
I hope this is useful.
JSL
JSL
