This is probably for you skinning guys. I would like to open a global overlay when I click a movie cover. Currently I use the default skin and the info screen is overlay:movieviewer. How can I make that global?
Steve
Hiller wrote:Thanks for the response Colby, I knew it had to be easy but I haven't worked much with the catagory stuff...
Lasse,
Global overlay will open the overlay on both the client and the server machine. The normal overlay will only open locally.
Steve
Colby wrote:dont use the word overlay: in the info screen. Open your overlay by adding an event (open global overlay) to the category instead. That should work.
