Ok it looks like that may work with some tweaks. I tested it at first with just my music and movies DB's. I tried at first just deleting all but those 2 DB's (after backing up
) and moving the whole folder to the Unraid server leaving no databases folder in the Xlobby folder and just having it on the Unraid box. I added the lines to the xlobby.xml file and made sure there were no databases in the skins area.
Xl came up but when I went to go into the DB's thru F2 I could see the data but then XL crashed. I then restored the databases folder to its normal location with all of the DB's except movies and music which are on the unraid server. Sometimes it would work for a little bit then crash sometimes at startup when it was initializing the DB's. I then remembered I did not set Xant to output to the unraid box, fixed that but still crashing. I copied just the music DB back to it's original location and had no crashes. I added some music and movies and they updated the DB's on the Unraid box not the normal databases folder
So what it looks like is I can move the movies DB completely to the unraid box after I update Xant's ini.
I can move the music DB but have to leave a copy of it in the normal place, for me c:\xlobby\databases\music.xml, although it does not seem to read or write to this DB but does read and write to the one on the unraid box.
I think all I will need this for is movies so I think this will work although I don't like to be tied down as far as somethings working and some not, so I may hack at it a little more
