whole house a/v
whole house a/v
Postby rkara on Thu Dec 28, 2006 1:01 am
Hi there all
I'm a newbie. But have experience in multi room audio.
Well it took me about 2 months of research and here i am
Looked at mainlobby, cqc. and girder. saw a post about xlobby decided to try
i've put xlobby to the test and i am very pleased.
here is my mission. Be able to run xlobby in 6 different zones.
bedrooms, kitchen,theater room and backyard. be able to stream audio(internet radio,and cd in library) video(cable and dvd collection), cams located around the house, control all lighting in each zone.
I will be using fujitsu 3400 tablet mounted in walls, have russound cav 6.6 to work with
any help will be appreciated.
rkara
Postby samgreco on Thu Dec 28, 2006 1:30 am
Welcome rkara!
I am in the process of doing the same thing, except I will be using a Xantech pre for my multi-zone.
The one BIG issue with using xLobby in this situation is that there is no native RS-232 driver. You can however, use Girder as a go between. Check out PhilB's LCars skin for ideas. He uses a Sonance multi-zone amp. I converted his Girder GML file for my Xantech and it works perfectly.
I have yet to start work on a skin to match because I am in the midst of starting a new business. But will jump in when I can. There are others here (well everyone else here) that know way more than I about the inards of xLobby :)
Sam
samgreco
Postby PhilB on Thu Dec 28, 2006 2:26 am
Damn I thought no one ever looked at my hacked system much less reused parts. I guess I should update my website to reflect the fine tuning I have been doing.
PB
PhilB
Postby samgreco on Thu Dec 28, 2006 2:35 am
Yes Please :D
The more I can steal, I mean reuse, the faster I can get it done.
samgreco
Postby rkara on Thu Dec 28, 2006 3:33 am
WOW!
DIDN'T REALIZE THERE WAS SO MANY OF US IN SEARCH FOR THE SAME THING.
ANYMORE INFO WOULD HELP ME GET STARTED.
SOON TO POST MY PICS OF SYSTEM ALREADY RUNNING.
rkara
Postby PhilB on Thu Dec 28, 2006 8:01 pm
I updated my website. Better overview of my system. Hope it helps.
PB
PhilB
Postby rkara on Sun Dec 31, 2006 1:04 am
thanks pb
this will do
one thing i tried your skin and also baddabigs
but can't get net radio to work
it keeps saying connecting then it stops
looked at every folder doesn't seem to be missing anything
again happy new year to all
rkara
Postby P3rv3rt B3ar on Sun Dec 31, 2006 1:47 am
This probably do not help anything, but ill say it just in case.
If u r using winamp, test using just winamp for shoutcast, without xlobby. If this doesnt work either, u might be having same wierd problem, i experienced, for me it fixed itself when i downloaded new version of winamp.
Postby rkara on Sun Dec 31, 2006 3:43 am
THANKS FOR THE QUICK REPLY
I'M RUNNING WINAMP V5.43
WHEN I RUN WINAMP I COULD STREAM MUSIC
BUT WHEN I LAUNCH XLOBBY THERE IS NO SOUND FOR THE STEAM
I DO HAVE ALL MY PLAYLIST, AND THEY WORK JUST FINE.
rkara
