by tka on Mon Jan 24, 2005 8:43 pm
I took my entire setup from the desktop (using Jowaldo's skin and with the most recent updates) and copied it over the the progear. Since that wouldnt' work, i copied everything to a different folder on my desktop, then edited a few things by starting that version of xlobby. i took out the start as server and adjusted the resolution, then copied it to the progear. same result, it gets stuck at "screens".
Then i downloaded qtip's media 2.05 (which is a full install) on the progear itself and that gets past the "screens" but gets stuck on "images" every time.
I guess i am unsure exactly how the fat client works: Should i take out all the database references to where the music and the photos are? does the client pc (i.e. the progear need to have foobar installed as well? Right now i don't have foobar in there but everything else (i.e. all the plugins etc).
I tried the thin client but it is just too slow and unresponsive to be of any practical use.
