I'm going to be putting together a HTPC soon and planning on using XLobby... hoping we get some serious DVB & HDTV tuner card integration so I can us it as a true HTPC!
I'm going to be needing to have 6 audio zones plus have it control my Home Theater room with 7.1 surround capabilities.
And want it all to be run from the same PC (yes I'm buying a serious machine!).
What sounds cards are recommended?
I'm thinking I'll need two SB Live (or something) plus a built-in 8 channel?
any other suggestions/advise is welcome!
thanks!
