Hello...
I have a working HTPC, on this I have all my music ripped in ape's and Flac, I don't know which one to use yet. Flac seems to have a wider support in applications.
Anyway I want to create a Tiny pc, which will access the htpc / server for music and use the PPC as a remote. I plan to hook this up with some very discreet speakers for the bedroom, via either wifi or with eternet, probably the former since i will need it for the ppc.
I have several questions relating to xlobby and my needs. I would really apprieciate if you have any answers.
1. Is it possible to have xlobby setup on ppc and pc for music only with no other menu's? I.E I want the ppc to go straight to the music page.
2. Will xlobby run on windows 98? I plan to use a really stripped out version of windows 98 using litepc.
3. Will xlobby run with out the explorer shell?
4. Why can i not download skins on the download page?
5. Do you have any recommentdations?
6. Does xlobby support lcd's specifically lcdc?
So they are a few of my questions probably stupid to some of you but your answers will be appreciated.
Cheers
Dan
