Skin booting to blank screen
Postby ForKChop on Mon Jun 21, 2004 7:07 am
Okay, got xlobby working with the default skin, however, when I try to change to one of the skins available for download it just has a black screen. No booting info or anything, just a blank, black screen. The touchscreen is set at 800x600 and no other changes were made. I tried the search, but couldn't find any instances like this. Did I miss something when changing the skin?
V
ForKChop
Postby jowaldo on Mon Jun 21, 2004 3:44 pm
Which skin are you using and are you using the latest builds of xlobby? Certain skins were made with older versions and may have some problems if they have not been updated.
Postby cavitycr33p on Mon Jun 21, 2004 7:05 pm
Make sure you extracted the actual folder, for instance I extracted xtuned, and it had a folder called xtuned within it. Thats how I got the blank screen. Make sure there isnt a folder within the skin folder you are trying to use.
cavitycr33p
