ppc seeing server screen
Postby cinemaworks on Thu Oct 07, 2004 11:32 pm
i have the latest jowaldo beta3 and the latest xlobby but everytime i start the client it shows the actual server screen and not the ppcmenu i have made sure screen is set to ppcmenu in server.txt but it doesn't seem to make any difference what i set it to as it always goes to the main server screen first. i can browse all screens on the server from the ppc and it works perfectly.. i just need a very good magnifying glass to read the text!!!!
please help this is really getting to me now. i have searched everywhere for an answer.
cinemaworks
Postby hjackson on Fri Oct 08, 2004 4:00 am
Are you sure there are not any other "server.txt" files in your PDA folder that may be messing it up. I know that the actual folder contents on my PDA can be misleading, depending on where I store things. To test this, delete the server.txt file who's menu you changed and see if the client still runs. If it does, your files have been misfiled.
Also, is this still a problem when you use the default skin? If it isn't, then it's probably a skin problem.
Good luck!
hjackson
hjackson
