Hi all. I am using XL with the MCEv2 remote and Girder4 and the XRemote plugin.
After lots of tweaking, it all works great except the remote seems to lose focus in one situation. I use a slightly modified default skin and when I go to MUSIC>SHOW>PLAYLIST the remote never gets focus on the playlist screen. However, if I use the mouse to go select (or highlight) a button on the playlist screen, the remote will work from there.
My thought is that there must be a setting in the playlist screen (in the skin) that is not set up right to gain focus... Any ideas?
