Tracie wrote: - looks awesome on my HDTV.
<-- me green with envy
As for the pop-ups, it's actually quite simple. Create a hidden button, give it an ID name. Then, under the special tab (I believe the tab is called special... I'm at work right now and I can't check) select the ID name of that button.
Presto! Now the hidden button will appear as you roll over it.
Pop-up text is done similarly. Create the text, give it an ID name. Then go to the button you want to activate the text, and under the special tab select the ID name of the text you just created.
Presto! Now the text will appear as you roll over that button.
Combine the two and you have a tool tipped hidden button bonanza. What could be more fun!?
