Removing superfluous buttons from Zoomplayer
Postby edgley on Tue Apr 27, 2004 10:39 pm
I would like to figure out where are the setting for removing the transport controls.
Any ideas please? I have been through the settings but can not find them
thanks,
s.
edgley
Postby MFan on Tue Apr 27, 2004 11:24 pm
edgley,
I am assuming that you just want to remove the buttons from the zoomplayer screen. Call up the edit box by pressing 'Pause Break' key. When the box appears, go to the tab 'Button' on the upper row of tabs and then 'Default' on the lower row of tabs. Highlight the button you want to remove by clicking on it on the screen and then press 'delete button' in the edit box.
Note - did I understand your intentions correctly?
Don
MFan
