Forgive me if this is answered elsewhere, but can't find it!
Bit of a newb to xlobby. Using Colby's excellent skin to learn the ropes. Here's what essentialy I'd like to achieve:
1. In the music database, a 'favourites' field on each level (artist, album and song) - ideally checkbox type, but text 'y' or null would do.
2. Display the present filter on the music screen. Present setup - lists artists first, then select artisits - get all the albums of that artist. Altered display so albums only have album name on them to prevent clutter. Is there any variable that I can use outside of the 'catagory' item (i.e. elsewhere on the screen). Surley the filter is stored 'outside' of the catagory item, centrally in the app?
3. The ability to display favourite artists, albums and songs - sub-filtering. Is this possible?
Here's what I've done:
1. Managed to add 'favourite field' to existing music import using databases>edit>add field (to all). However, when I add a new folder to my existing import path and import that data, misses off creating a 'favourite' field for this new addition. I presume it is impoting to the template music db structure (i.e. minus the favourite field).
2. Messed around with all sorts of variables in all sorts of places using colby's variable list. Can't crack it!
3. Haven't even tackled this yet!
Q's:
1. Is it possible to change the default format of the music database. If so, where? Looked in templates folder and one seems to be params for import (eg. file extensions etc) and the other the actual data. Also - xml - bit wierd to me - familiar with realtional db's like access and mysql, but this all seems a bit weird.
2. Is it possible to change db fields whilst using the app? i.e. I would like a symbol on the pictures of the arstists, albums and near the now playing which will toggle favourite on/off. How would I do this?
3. Is it possible to 'translate' one db into xlobby's? (e.g. an app matching fields). Presently have a db for both my music and off-line movie collection, just need to get the data from those into xlobby.
4. When importing via id tags, do all the songs in an album need to be tagged with the album picture or just one of them (have I read somewhere that there are spearate tags for album picture and song picture)?
Apols for long post, but I'm stumped![/list]
