Hi all,
I just got a usb-uirt, and I have noticed that some remotes work better with it than others. For instance, I told my harmony to emulate a Microsoft MCE remote, then learned the IR commands into xlobby. When controlling xlobby with the MCE remote emulated, it is suggish. But, if I learn the buttons from my PVR remote device into xlobby (using the harmony), it is not sluggish and works well.
Can someone suggest a good remote to emulate with my harmony 676 that will work well with xlobby and the usb-uirt?
Thanks!
Kevin
