A new forum to play around in
Postby stevenhanna6 on Tue Mar 06, 2007 6:49 pm
This link is to a test forum, I wont be upgrading to this forum any time soon because its beta still....but I will be occasiconally going over there and messing around with it to see what its like. If anyone wants to check it out, you can go here
http://www.explode.ca/forum/phpBB3/
Dont post anything important there because its just a test area.
Postby abobader on Tue Mar 06, 2007 10:45 pm
Steven,
That look cheap :)
Since you on business now, why not use paid forums like IPB or VB one? will sure look better for the image as well easy options and a like.
My best.
abobader
Postby stevenhanna6 on Tue Mar 06, 2007 11:41 pm
yah I'm just testing it, I will take a look at the paided ones also. I was of course going to change the skin of the forum if I decided to switch over later on..that default one sucks :)
I'm just so used to programming into phpbb thats why I was looking at their new software. But like I said I just wanted to see what it was like and get some feedback on it, I do like the attachment features...that will be a must for a new forum. There is other admin stuff in there that I have never seen before too.
