Sean,
We have recently added the ability for xLobby to use graph files from external players to reliably play MPEG-2 files from the internal player. You can select a graph file from the setup menu (F2) under media player (DVD Graph), the current graph support can be set for default meaning the current MPEG-2 decoder installed on your system or for Power DVD software, so if you installed power DVD versions 4 and up xLobby should have no problems playing MPEG-2 files, (DVD's). Additional graph files will be included in the final release of xLobby, so other DVD playback software will be fully supported and shown in the list. This will always secure the correct graphs for playback. The graph files will provide users the ability to modify the graphs using software called GraphEdit to modify decoders of video and audio as necessary, providing a user configurable decoding system.
More Information on GraphEdit:
http://www.digital-digest.com/dvd/downl ... t_141.htmlhttp://msdn2.microsoft.com/en-us/library/ms787855.aspxIf you do not have a MPEG-2 decoder installed in your system then you can download FFDSHOW, if other decoders are installed in windows then it will pick the current decoder that was last installed or selected by the other mpeg-2 decoder software thru windows. This sometimes creates problems for xLobby to correctly decode MPEG-2 files using FFDSHOW as this decoder may not always be the default decoder in windows. If xlobby will not play MPEG-2 files correctly and consistantly then it may be necessary to un-install all of the other MPEG-2 decoders \DVD playback software in your system, and again this will not always guarantee complete removal of the mpeg2 decoders from windows.
Posted information from the Download page on MPEG-2 decodersIf you plan on using xLobby's default built in media player (direct show based) for your playback, you should keep in mind that you might have to install various codecs. Sometimes a codec will be needed to play a certain video and audio format that is not usually playable on a standard installation of Windows.
For example, if you wish to play a DVD you will require what is called an MPEG-2 decoder. The reason behind this is that Windows cannot play DVD files without it. Some installations of Windows will come pre-loaded with a DVD decoder, some will not. xLobby does not currenly come with an MPEG-2 decoder, but we do have plans to include one.
There are many different video and audio formats on the internet, the link below is to a free piece of software called "FFDShow" which is an "all in one" audio and video decoding filter. It supports many different media formats including the video formats DivX, XviD, MPEG-1, MPEG-2, MPEG-4, H.264 and the audio formats AC3, DTS, MP3 and Ogg Vorbis. To download "FFDShow" and for more information see the links below.
Download Stable Build FFDSHOW rev. 610 (20061201)
http://www.xlobby.com/filters/ffdshow_r ... _clsid.exewikipedia ffdshow ,
http://sourceforge.net/projects/ffdshowsourceforge ffdshow ,
http://sourceforge.net/projects/ffdshowI hope this helps.
