by billberet on Wed Dec 03, 2008 5:36 pm
ok here you go
1. I assume you are using the ATI card you purchased (Y/N)
correct, i am using Radeon HD 3870, at the hardware level i have the plasma set as theater mode, where any video being played gets sent to that device. I have the property of the plasma set to keep the aspect ratio of the source
2. I thought you rendered video only on the plasma and touchscreen is only control (Y/N)
correct, xlobby main screen is the touchscreen, so when i am in media player, i see the window version of the movie with all the controls, the F keys move the video on the touchscreen as well as the plasma
3. Does the gui fill the plasma display from top to bottom (Y/N)
in xlobby, if i make the plasma my primary display, xlobby menu shows on the screen from edge to edge.
but i keep xlobby on the touch screen only.
then when i've had enough i hit F11 to reset, and i get the full width, with top and bottom bars squishing the image to an egg shape.
it happens in this order
f11 - reset (gives me full width, with top and bottom bars)
f5 - i hit 5 times, the picture in the media player starts to enlarge vertically as many times as i hit the button, but the plasma only enlarges vertically once.
f5 - touchscreen enlarges more, plasma now displays vertical bars, and gives me the picture frame effect, but aspect ratio is correct
f5 - touchscreen is streatched out vertically loosing aspect ratio, but plasma picture frame gets larger, keeping aspect ratio of the image while the vertical and horizontal bars get thicker, essentially video images gets smaller (staying in 16:9 ratio)
The F keys will only effect the video rendering window not the skin. If you have the video card setup for mirrored output
then what resolution is the touchscreen set at and what resolution is the plasma set at.
i am not doing mirrored output, i used extended desktop, this way i can have the proper resolution on the plasma.
plasma is set for 1280x720
and touchscreen is 800x600
within windows, the plasma has no bars, i have full screen if i bring up any window and drag it to the plasma, i can move it from corner to corner. outside of xlobby.
while in xlobby, the plasma will have the windows background on the screen, still no bars, looks normal, until i press play, then the video gets pushed and i have the picture effect with the borders. if i increase height and width of the video being rendered, it will start to increase, then start get squished. while the video on the touchscreen is still increasing normally with the F keys.
this only happens during movie playback, when i play avi files, they stretch to full screen, but i'm not concerned about that yet. it's on the ta-do list, i know. since most of my video's are 4x3.
