can anyone provide me with the install file for the november 24, 2006 build date?
i just about completed my xlobby skin and wanted to check it out on my htpc which had an older unused version...i uninstalled it, reinstalled the install file that i kept in my xlobby dowloads folder but it turned out to be an older one as well...
when i dl'd the 11/24/06 version i began using in exclusively but i must have deleted the install file...
can anyone help?
steve or wes, i hope this is ok with you as i know you are guiding people to the new versions for testing but i want to noodle with that separately....
