tswhite70 wrote:Are you using the Calrad version of Xlobby? Sounds like some kind of problem with your launch movie event - maybe the internal player is also trying to play the movie or grabbing your soundcard outputs at the same time or something weird. Try this - start TheaterTek and then start Xlobby, play a movie manually in TheaterTek. Still have sound after you stop TheaterTek? If so, create a new event in Xlobby using OS>Execute, put in whatever the correct command line options are for Theatertek and hardcode a movie path in the event. Run the event from F2, stop TheaterTek. Still have sound? If so, point your "Play Movie" button at the new OS event you created, substitute your hardcoded movie path in the new OS>Execute event with %movies>parameter%. Play your movie.
good luck,
tsw
tsw,
Thank you for replying and you gave excellent suggestions, here are the steps I followed:
1. Rebooted HTPC
2. Started TheaterTek 2.6
3. Started Calrad's Comerical Xlobby 2 (latest build)
4. Comfirmed sound worked wtihin Xlobby 2 (play some music, hear beeps during navigation, etc)
5. Manually play a movie within TheaterTek 2.6
6. Comfirmed sound is working correctly TheaterTek 2.6 (I'm recieving Dolby 5.1 from my Marantz Reciever via SPDIF/Toslink)
7. Stopped movie, exited TheaterTek
8. Comfirmed sound no longer working within Xlobby!
9. Comfirmed sound no longer working within any Windows program, except TheaterTek
10. Restarted Xlobby, all sound comes back
Also if I go in standby (S3) and come back out of standby my sound comes back. There is some issue with Xlobby and TheaterTek I'm positive about this now.
I hope that Steven responds to my email to let me know how I can debug this because its driving me nuts.
