access db info from in-side a plugin?
Postby S Pittaway on Wed Mar 22, 2006 10:57 am
Apologies in advance if i am asking a stupid question :)
how do you access db info from inside a plugin.
eg, say i wanted to get the currently selected albums name and genre is there an easy way to do it?
Postby m_ski on Wed Mar 22, 2006 12:28 pm
Use the xhelper.ConvertVariables() command. Pass the string of the parameter you wish to get inside the brackets. (The same string you would use to display the parameter in a screen)
e.g.
plugin_string = xhelper.convertvariables("category>music>albumname")
or
plugin_string = xhelper.convertvariables("category>music>genre")
See http://www.xlobby.com/forum/viewtopic.php?t=3086&highlight=convertvariables
m_ski
Postby S Pittaway on Wed Mar 22, 2006 1:11 pm
I downloaded the xstats pluging and started off with that...
The copy of XPluginSDK.dll in there is from 2004, i dropped in a the new one from the xlobby folder and a lot more functions now show up :)
Cheers.
