Help with setting up Xlobby3+TMT3
Postby snsumner on Thu Mar 25, 2010 4:01 pm
Hello,
Can anyone share their configuration settings for using Xlobby3 with TMT3 for DVD/Blu-Ray playback.
Regards,
Scott
snsumner
Re: Help with setting up Xlobby3+TMT3
Postby lpg on Fri Mar 26, 2010 1:50 pm
Here is the news release that I used to set it up. http://xlobby.com/news/2009/06/13/new-xlobby-v3-build-30916326/.
I do remember running the Mediaserver version which is in the TMT3 program directory.
If there is a mediaserver device for your harmony this could work.
Postby CaM on Fri Mar 26, 2010 8:59 pm
hi, for tmt 2 / tmt 3 I use Event Ghost along with Xlobby.
i.e. xlobby play button > event ghost > find window > send key
does that make sense?
CaM
CaM
Postby Grooby on Sat Mar 27, 2010 12:05 pm
I use TMT3 and Zoomplayer with xlobby3, xlobby3 natively controls TMT3 now from its movie controls screen (look at the xlobby triggers) and their remote control. I also associated the zoomplayer commands to the same media buttons as TMT3 in my skin under events so the one playing screen controls both programs.
