Badubo, what is the state on the xltv-plugin. Any updates..?
Did you get any time to look into a Sheduler?
Rika
badubo wrote:if your card in compatible with either k!tv or progdvb (or dvbdream), you can download the very first alpha version :
http://www.france.xlobby.com/plugins/xltv.zip
the plugin is configured for french epg, but you can easily adapt it to your need in the EPG tab
Do you know if there are some way to search in the epg? Is an abc-overlay possible
I cannot, however, delete any scheduled programs for some reason. The scheduled program will not be removed neither in xltvscheduler.xml, in xltv.dllschedule.dat nor in windows Windows Scheduled Task.
Furthermore, is there any smart way of both recording and viewing TV (two different channels) at the same time using your plugin (I have two TV cards).
