by jbretsch on Fri Sep 08, 2006 2:08 am
Sounds like a part of my project. I wanted to make my home theater more user friendly by adding a touchscreen PC.
If this is all you want to accomplish you would be better of with USB-UIRT or one of the Ir devices that is supported as a plugin in XL.
Unless you can find (or develop) a plugin for Global CacheXL, you are better of with putting girder in between. If you can find a version 3.x it is actual free, where version 4 is not.
I decided to go with girder, as i had other requirements as well and my IR receiver and remote is not supported directly.
