Navigation
Navigation
Postby mfergusson on Sat May 20, 2006 2:55 am
Hi,
I have a number of buttons on a screen. When navigating down a columns and it gets to the end, I want it to move the focus/selection to the button at the top of the next row.
What it does by default is take the user to the top of the same row.
Can this be done?
Mark
mfergusson
Postby Colby on Sat May 20, 2006 3:00 am
for buttons use navigation overide expained in my skinning doc. For categorys use snake scroll option.
Postby mfergusson on Sat May 20, 2006 3:18 am
Thanks, works well.
BTW, what version of xlobby was used for the screenshot in the guide? It looks better. Perhaps I need to update?
Cheers
mfergusson
Postby jowaldo on Sat May 20, 2006 6:03 am
mfergusson wrote:Thanks, works well.
Cheers
this is the latest exe...
http://www.xlobby.com/xlobby2screentest.zip
