How do i run xlobby on windows xp x64?
Postby Stuie on Tue Apr 17, 2007 10:47 am
So, how do i actually run xlobby2 on a windows xp x64 O/S?
I've tryed all the different versions of .NETframework.
I also read an old post at this forum about this, but I think xlobby was using .NETframework 1.1 at that time, and not 2.0.
//Stuie
Stuie
Postby Stuie on Wed Apr 18, 2007 11:28 am
Ok, after reading how to run framework x64 as 32 bit, ive discoverd that it's not really the framework i got a problem with, its the DShowPlayer.
At the startup it pop's up a error wich looks like this:
System.BadImageFormatException: Could not load file or assembly 'DShowPlayer, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
File name: 'DShowPlayer, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null'
   at xlobby2.InternalSounds..ctor(Control control)
   at xlobby2.Control.LoadAll()
   at xlobby2.GdiScreenForm.GdiScreenForm_Shown(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnShown(EventArgs e)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
xlobby2
    Assembly Version: 1.0.2652.34618
    Win32 Version: 1.0.2652.34618
    CodeBase: file:///C:/Program%20Files%20(x86)/xlobby/xlobby2.exe
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
XPluginSDK
    Assembly Version: 1.0.2628.35183
    Win32 Version: 1.0.2628.35183
    CodeBase: file:///C:/Program%20Files%20(x86)/xlobby/XPluginSDK.DLL
System.Management
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
enabled.
For example:
<configuration>
</configuration>
Is it the dvd player that doesnt support x64?
//Stuie
Stuie
Postby Stuie on Fri Apr 20, 2007 11:39 am
Nobody knows?
Would be great with just a tiny amount of help.
I'm pretty close to install 32bits again cause of the problem with xlobby, cant live without it. Thanks
//Stuie
Stuie
