6th Pre-Release Ready
Postby stevenhanna6 on Sat Aug 04, 2007 7:14 pm
http://www.xlobby.com/xlobby_2.0.7214.0.exe
Expires September 9th 2007
Ok whats new in this release, a couple of minor fixes. This is because there are now two versions of xlobby I'm working on as I transition to the new .net 3 platform. So this is basicly the same as the last build but with the expiry date extended to give me more time to work on the .net 3 version. Once I get the .net 3 version up to par it will be released.
I dont want to go into too much detail as to what the difference will be in the .net3 version I'll save that for another thread. I should be able to start posting some screenshots of it late next week.
Re: 6th Pre-Release Ready
Postby rika on Sat Aug 04, 2007 9:39 pm
Great news! Thanks
Rika
rika
Postby cooldog on Wed Aug 08, 2007 12:13 pm
Steve,
Although I can get the XAntMovie plugin to rewrite the movies.xml database from inside the skin, I cannot seem to get XLobby to reload the movies database without restarting.
Please see the messages starting here: http://xlobby.com/forum/viewtopic.php?f=14&t=2604&p=40651#p40626.
I'm not sure if this is pilot error (although at this point I think I've tried everything possible) or an issue with the newer versions of XLobby.
Paul
cooldog
Postby blopa26 on Thu Aug 09, 2007 2:33 am
Steven,
I downloaded this 6th release and something new that I can't understand the reason why changed, is in the HTML Code... Let me show you the HTML generated now:
<html><head></head><body><img width=0 height=0 border=0 src="http://192.168.0.103/fakeimage.jpg"><a href="http://192.168.0.103/1259994252/map"><img border="0" src="http://192.168.0.103/1259994252/screenshot1259994252.jpg" ISMAP></a></body></html>
As you can see, there is a new instruction that ask to show a jpg called "fakeimage.jpg"... I can't find this image in the xlobby directories (I only made a partial update), so my 3Com Audreys are showing the typical symbol that indicates a "not found" image (an "x" inside a square box).
What is the reason of this change?... Will you eliminate this instruction, or to create the image, or let me know how to get it?...
Thanks in Advance, Pablo
blopa26
Postby stevenhanna6 on Fri Aug 10, 2007 3:07 am
blopa26, your right that was some left over code from some testing me and Wes were doing with a new hand held tablet. It's built in browser wasn't behaving properly so we were trying to come up with a work around for it. The "fakeimage" code will be removed in future versions, it slipped by in this release.
Postby blopa26 on Sat Aug 11, 2007 4:15 pm
Steven, Thanks for your reply... As far as I understand there isn't a workaround now, just wait for a new release... Taking advantage of this post, can you tell me if you're doing something to stabilize the Web Server now, or if this is not in your short-term goals with XL?...
blopa26
Postby cooldog on Sat Aug 11, 2007 5:40 pm
blopa26 wrote:Steven, Thanks for your reply... As far as I understand there isn't a workaround now, just wait for a new release... Taking advantage of this post, can you tell me if you're doing something to stabilize the Web Server now, or if this is not in your short-term goals with XL?...
Pablo,
Why not make a single-pixel jpeg image, and name it fakeimage.jpg ? Ask Steven where to place it ...
Paul
cooldog
Postby blopa26 on Sun Aug 12, 2007 1:13 am
Thanks for your idea... I already did it and works fine... Unfortunately the stability problem in the Web Server was not fixed yet... Pablo
blopa26
Postby cmhardwick on Thu Sep 06, 2007 10:40 pm
this release expires before Cedia ends. Are we all just out of luck on this? Expires Sept. 9, last day of Cedia.
Postby capecodscot on Fri Sep 07, 2007 1:24 pm
Yes , this is pretty concerning. I built a whole new skin based on this pre-release to get to grips with it. I hope the effort was not wasted.
capecodscot
Postby Robertsonland on Sat Sep 08, 2007 2:21 pm
So are we not going to have a release before the current version expires in about 16 hours or so?
Robertsonland
Postby samgreco on Sat Sep 08, 2007 2:30 pm
Considering that everyone is at CEDIA and the show doesn't end until tomorrow, I'd bet not.
samgreco
Postby wesblack on Sun Sep 09, 2007 2:40 am
Steven is updating the new build and extending the expiration date.
Postby stevenhanna6 on Sun Sep 09, 2007 2:52 am
Wes beat me to it, here is the link to the new prerelease
viewtopic.php?f=23&t=5909
Postby samgreco on Sun Sep 09, 2007 5:47 am
Well yo guys are obviously not in the spirit of trade shows. You're supposed to be out drinking until the wee hours so that the pain from the hangover the next morning over rides the pain in your feet.
I've done many. This is the first CEDIA I haven't been too in a long while.
Glad to hear the show has gone well.
samgreco
