I can play any client zone from the server but not the server zone from a fat client. I just get the red cross when selecting my zone screen from a client.
(I´m working on a new skin with zone controll but can´t get this to work
Rika
System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Server stack trace:
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at System.Runtime.Remoting.Channels.RemoteConnection.CreateNewSocket(EndPoint ipEndPoint)
at System.Runtime.Remoting.Channels.RemoteConnection.CreateNewSocket()
at System.Runtime.Remoting.Channels.SocketCache.GetSocket(String machinePortAndSid, Boolean openNew)
at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.SendRequestWithRetry(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream)
at System.Runtime.Remoting.Channels.Tcp.TcpClientTransportSink.ProcessMessage(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream, ITransportHeaders& responseHeaders, Stream& responseStream)
at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at System.Object.FieldGetter(String typeName, String fieldName, Object& val)
at xlobby2.Control.GetZone(String name)
at xlobby2.Command.ReplaceVariables(String args, Control control)
at xlobby2.PicButton.drawImage(Graphics g, Control c)
at xlobby2.GdiDraw.DrawButton(PicButton ptemp, Graphics g, Control control)
at xlobby2.GdiDraw.DrawFormButtons(Graphics g, ArrayList buttons, Control control)
at xlobby2.GdiForm.DrawToGraphics(Graphics g)
at xlobby2.GdiScreenForm.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 1.0.2443.23075
Win32 Version: 1.0.2443.23075
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/xlobby2.exe
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
XPluginSDK
Assembly Version: 1.0.2407.36634
Win32 Version: 1.0.2407.36634
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/XPluginSDK.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CDEX
Assembly Version: 1.0.1685.4787
Win32 Version: 1.0.1685.4787
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/CDEX.dll
XMoveWindow
Assembly Version: 1.0.1808.42027
Win32 Version: 1.0.1808.42027
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/XMoveWindow.dll
XMpc
Assembly Version: 1.0.1903.30052
Win32 Version: 1.0.1903.30052
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/XMpc.dll
xstats
Assembly Version: 1.1.1661.40181
Win32 Version: 1.1.1661.40181
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/xstats.dll
xusbuirt
Assembly Version: 1.0.1767.29466
Win32 Version: 1.0.1767.29466
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/xusbuirt.dll
XoapWeather
Assembly Version: 1.1.1729.14788
Win32 Version: 1.1.1729.14788
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/xoapweather/XoapWeather.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
slx3bged
XWeather
Assembly Version: 1.0.2387.38391
Win32 Version: 1.0.2387.38391
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/plugins/xweather/XWeather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/Interop.Shell32.DLL
System.Web
Win32 Version: 2.0.50727.210 (QFE.050727-2100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
CustomMarshalers
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/Program%20Files/xlobbyCLIENT/Interop.ActiveHomeScriptLib.DLL
enabled.
For example:
<configuration>
<system>
</configuration>
