Edit Menu Options, Remove Buttons
title says it all
Postby zero260 on Mon May 21, 2007 9:23 pm
I haven't had much luck searching what I need to find out and it seems like this would be an easy answer for Xlobby Pros...
Basically i want to use Xlobby in a "not so typical" application.
My question: "How do I remove the feature I do not need?"
For example... I am using a skin that offers:
MUSIC
MOVIES
TV
GAMES
PHOTOS
WEATHER
For now, ALL I WANT is PHOTOS & WEATHER.
I must be missing something, but I don;t see an easy way of doing this??
Z
zero260
Postby smarty on Tue May 22, 2007 1:17 am
Just enter the screen editor (hit the pause/break key) and from here you can delete whole screens, or you can select items within a screen and then delete individual items. You can also change screens from there.
Hope this helps!
smarty
Postby zero260 on Tue May 22, 2007 4:52 pm
Great. Wow.
I was thinking I was going to have to manually edit XML files.
Pretty cool how you can move buttons around also!
Thanks a bunch!
-Z
zero260
Postby P3rv3rt B3ar on Tue May 22, 2007 6:50 pm
Also notice that in some skins menu is actually category representing database. In thatcase u cant delete individual buttons just by skin editor, but u need to edit database, by removing unwanted items with database editor accessible via setup (F2).
Re: Edit Menu Options, Remove Buttons
Postby bmblank on Tue Jun 26, 2007 7:12 pm
Just kinda dickin around at work here... I have a question.
Why would having a menu set up as a database be better than just individual buttons?
bmblank
Postby dalanik on Tue Jun 26, 2007 8:09 pm
bmblank wrote:Just kinda dickin around at work here... I have a question.
Probably easier to edit/change and also you can have multiple items on 1 button (without states).
Return to Tips and Tricks
