zoomplayer 5
title says it all
zoomplayer 5
Postby cinOxen on Tue Nov 21, 2006 8:27 pm
On the command line the %parameter% variable (path) now needs to be in quotes: "%parameter%"
cinOxen
Postby sagitaz on Tue Nov 21, 2006 10:02 pm
true and false.
for all external program you need write "%parameter%" if you have space in the path off file.
exemple :
D:\movies\mymovies.avi = %parameter% work very well
D:\movies\my movies.avi = %parameter% don't work you need add the ""
:wink:
sagitaz
Postby cinOxen on Tue Nov 21, 2006 10:51 pm
Lol, I'm embarassed :oops:
That is just such strange timing. I had it setup without the quotes and never had a problem opening files and can only assume it was because none of them had spaces. I install the new zoomplayer and the first two files I try to open have spaces so I assumed it was zoomplayer that changed.
Oh well if the unlikely event occurs that someone is as much of a newb as me maybe this thread will help. :)
cinOxen
Return to Tips and Tricks
