Casting stars on your movies
title says it all
Postby P3rv3rt B3ar on Mon May 29, 2006 5:08 am
I wanted to set (rating) stars on each movie icon in a category, not just for selected one. This appears not to be currently possible. However i deviced a workaround for this. Its not particularly elaborate, but i decided to report it in here anyway. Heres the screenshot from endresult (notice yellow stars on movie covers) :
now what im basicly doing is using wingding character for star. which is «. U have to set a new field to movie database which value is 1 to 5 of that character, and u better do it where your skin set stars for rating. In example dragon skin is used, and in it theres buttons for setting each number of stars, so basicly you go to events and find db>starsX events and add to them one more set database field (where field is name of your choige, forexample tahdet, and value is X amount of star character)
After the setting of tahdet field is done... all there is left to it... is displaying it. Go to the categorys gategory tab and change display text field to %tahdet% or whatever name u gave to the database field, then go to Display tab and do change font to wingdings, also on that tab u do final finetuning like color, size, and location of stars.
Now this is limited workaround... unfortunately u cannot display any other text with category item imbued with stars and stars are tied to single (possibly two if u use edge) colors. Ill make suggestion on feature request but until that gets implemented this is the way to cast some stars.
Postby bmblank on Mon Sep 25, 2006 8:43 pm
You only gave bad boys 3 stars??? It is WAY better than that!
Bad boys bad boys
whatcha gonna do when they come for you.
bmblank
Postby P3rv3rt B3ar on Mon Sep 25, 2006 10:03 pm
Damn!!! u r right those stars are all f*cked up! ive must been taking too many mushrooms on that day... Arizona Dream and Bad Taste should have three stars... and u r right about the fact that bad boys has error too... however, it should have only 1 star... and after seeing second part im not too sure about even that :D
Postby bmblank on Tue Sep 26, 2006 12:22 pm
Bad boys II is even better than the first!
bmblank
Postby P3rv3rt B3ar on Tue Sep 26, 2006 12:39 pm
haha, i just cant wait how uber bad boys are in part III
Postby bmblank on Tue Sep 26, 2006 12:54 pm
They'll be bad old geezers by the time there is a bad boys III. Not gonna happen. At least if they know what is good for them they'll quit while they're ahead.
bmblank
Postby P3rv3rt B3ar on Tue Sep 26, 2006 5:25 pm
bmblank wrote: At least if they know what is good for them they'll quit while they're ahead.
Oh they still have long way to go to reach "dotcom for murder" :D
Return to Tips and Tricks
